Bobupndown
What could possibly go wrong?
- Northern Ireland
Any suggestions on cutting aluminium sheet, 2 - 3mm on a DIY basis? What is most effective method?
I cut a lot on a varga va1 with a tungsten tipped blade also...
Jigsaws actually work quite well
Personally out of ease as I’m normally within arms length of one I just grab an angry grinder.
Use the thinnest discs you can get. 0.8 on a 4 1/2” work the best. Hold a candle above the cut so you’re cutting the material and the candle at the same time.
You can rub wax along the line but holding the candle works the best.
Circular saw with TCT blade will work.
I use a Aluminium cutting wax, think it's Trendiwax.Any tips for a secret sauce to stop it sticking to the cutting tool? Or is the blue and yellow can a good price/performance balance? Thanks.
I've found aluminium eats the normal (I'm using Bosch Inox) ones far quicker. For a quick one off small cut though it's not worth changing disc!Normal Inox ones work fine for me, the specific Alu ones fractionally better but not enough to make the extra cost worth it. Having said that the vast majority of my Aluminium is 5083 and it cuts a lot better than softer grades.
