Tractor Man
- Devon, UK
Hi
I have just bought this off Ebay, it was for sale from a company dealing in machine returns and had no guarantee and was not guaranteed to work. The torch and earth clamp were missing but I got it ridiculously cheap (£30!)compared with the normal price of these cutters.
The cutter arrived today and I found that the airline intake on the back was blocked up with saw dust (maybe why it was sent back?) Anyway I plugged it in to see if it actually turned on. The fan started up and the red light in the on switch came on.
I then took the cover off to look inside; it was far more complicate than I thought. Anyway I found some LED’s on one of the boards (diagnostics system?), when I turned the power on only a green LED was on so I assume there are no problems with the internal electrics?
On the front panel of the cutter is a small red light with the letter 'OC' above it, should this light come on when the cutter is switched on or is it a warning light?
The next step is to get a torch and earth lead and try it, however I need to be sure before I spend any money that the cutter will actually work, any thoughts?
Does anyone know where I can get an instruction manual for this cutter? Also where would be a good place to get a torch (cheap!), I had a look at Shop-river on Ebay and they seemed to have some good deals. Also should there be a filter on the back for the air, or is this only optional?
Any help would be greatly appreciated, as this is my first plasma.
Thanks
Will
Thanks
Will
