Wedg1e
They call me Mr. Bodge-angles
- Teesside, England
Ah, so about the same volume as a classic Rangey which had 5 Lucas wires
And that's why bus based systems like Canbus were introduced ! There comes a point where using a bus is simpler than traditional wiring.
I would imagine it has canbus as well on a 5 year old car?And that's why bus based systems like Canbus were introduced ! There comes a point where using a bus is simpler than traditional wiring.
Yeeees... and then they come up with the sort of silliness where the central locking modules have to be 'coded' to the body control module - and still needs 5 wires between the two (Landrover, I'm pointing at you).And that's why bus based systems like Canbus were introduced ! There comes a point where using a bus is simpler than traditional wiring.
I see. Maybe if the bus system was more standardised then it would be easier to deal with.Yeeees... and then they come up with the sort of silliness where the central locking modules have to be 'coded' to the body control module - and still needs 5 wires between the two (Landrover, I'm pointing at you).
WTF was wrong with simply reversing the polarity on a DC locking motor?
CAN BUS is completely standard and universal in its application. The problems/variations come when manufacturers get hold of it and start using it to connect their own weird/wonderful/pointless gadgets and ECUs. They have to allow third party access, but they don't have to make it simple and try to use as many of the loopholes as they can to prevent full access. Security and safety are their top two favourites as blocks to allowing access. So it frequently ends up as a complete dog's breakfast.I see. Maybe if the bus system was more standardised then it would be easier to deal with.
See, I'd have been the same... except I don't wear PJsI do remember the fun I had with a Rover K-series ECU wiring and sensors. Could not get it to fire and run. About midnight one day, laid in bed, had a thought . . . into the garage, in the PJs, pulled the cam cover off . . . ah-ha! No flippin' reluctor on the after market cam . . . tune out cam position sensing in the ECU and twenty years later, it still starts and runs well.
When I first heard about CANBUS, it was talked of as a 2-wire system. Power down one (heavy-duty) 'ring main' and data down the other, ground via the chassis.CAN BUS is completely standard and universal in its application. The problems/variations come when manufacturers get hold of it and start using it to connect their own weird/wonderful/pointless gadgets and ECUs. They have to allow third party access, but they don't have to make it simple and try to use as many of the loopholes as they can to prevent full access. Security and safety are their top two favourites as blocks to allowing access. So it frequently ends up as a complete dog's breakfast.![]()
I've drawn up the wiring diagram for the custom loom, it's a serious amount of wiring for a 90's engine with 12 sensors/controllers.
Full spec CAN bus is two data wires plus power wires.When I first heard about CANBUS, it was talked of as a 2-wire system. Power down one (heavy-duty) 'ring main' and data down the other, ground via the chassis.
I'd presume earths?
I was thinking that some of them might need to be screened cable as well.If they are then it's highly advisable that each sensor has it's own signal ground back to the ECU if it has the pins to accomodate it (which it should), to avoid the ground offset problems that can come with shared returns.
Certainly signal grounds are typically direct from the ECU, and changing that could lead to problems.If they are then it's highly advisable that each sensor has it's own signal ground back to the ECU if it has the pins to accomodate it (which it should), to avoid the ground offset problems that can come with shared returns.
They might be.I was thinking that some of them might need to be screened cable as well.
Yep the triangles are earths. Diagram was drawn using genetic software so there aren't proper symbols available. Not sure what the best software is for wiring diagrams? I resorted to draw.io (now diagrams.net).
So is Canbus the way of sending messages but doesn't define what the messages mean ? Not unlike serial then? If so then who or what standards defines what the messages mean ?CAN bus is just the protocol for communication, the actual implementation can vary quite a bit.
Ah, is that why the ECU has multiple grounds? I was meaning to ask about that. Thanks.If they are then it's highly advisable that each sensor has it's own signal ground back to the ECU if it has the pins to accomodate it (which it should), to avoid the ground offset problems that can come with shared returns.
Yes the Oxygen sensor is screened on the original loom. I'll add that to the diagram.I was thinking that some of them might need to be screened cable as well.
