hotponyshoes
- Somerset. Uk
I have a project that requires the use of a current monitoring relay (basically a box with 2 socket outlets. Both live but the output in one socket needs to be switched off when the load on the other exceeds a couple of amps)
I have got one of these
www.gavazziautomation.com
Obviously not suitable for this project as it only has 2 wires to connect. I can not work out what these are actually for?
As in, what does the relay part do if there are no connections for the relay?
DIA53S72420A
1-phase AC overcurrent monitoring relay, input range 2-20 A AC, NPN-PNP open collector output, self-powered, 17.5 mm DIN-rail housing
