Prajna
Fixing things for the love of it
- Castelo Branco, Portugal
So, I have expended a little mental exertion on the problem of stopping the device.You realise that once you start it you'll never be able to turn it off?
The reason it runs (if it runs at all) is because the metal tabs are aligned with the converging parts of the cam tracks. It would be simple enough to mount the tabs on a ring that can be rotated independently but relative to the rotor so that the tabs align with the crossover (where the tracks switch from converging to diverging) rather than with the convergence. That will stop the device since it will block the repulsion where the tracks diverge. Rotating the control ring further will align the tabs with the diverging tracks, so the machine will run in reverse.
It could be arranged simply by using an eccentric cam that turns in a slot, biasing it in one direction or the other. A clamp could be arranged at the rotor axle so that closing the clamp rings rotates the cam so that the control ring miss-aligns with the converging sections of the cam tracks.
It will complicate the design a little, of course, for which I have already been criticised, however complication is necessary to some extent, so long as there is not more complication than is necessary to implement a feature then little can be done about that.
