wheresmejumper
Banned
what plastic capping do you mean?
this stuff http://compare.ebay.co.uk/like/180873805858?var=lv<yp=AllFixedPriceItemTypes&var=sbar&adtype=plawhat plastic capping do you mean?
oval or flat capping can be used. the advantage is if u do use it u can generaly pull new cables through with it if u rewire in later years or pull extra length of cable if the ends get burnt. flat capping is easier to fit as u dont have to pull the cables through itnever seen it,is it used instead of oval conduit?
why would u need it with insulation ? its there to protect against mechanical damagepolystyrene insulation is used a lot though,so that plastic capping or oval conduit is needed
