Craigybaby37
Hi I'm new to the forums and have a couple of questions regarding my sip t130p welder as I would like to get the most out of it.
Question 1: The welder I have has 6 power setting on 3 switches the instructions don't say anything about the amps for each setting? Does anyone know what they are roughly?? The switch on the left has high and low, high being the highest setting from what I have worked out but if you press the switch onto low does it then let you use the other 2 switches I have never been able to work out what way round the switches go to achieve different power levels?
Question 2: may be to do with question 1 but here goes. Welding 4-5mm steel on the highest setting (left switch on high) is fine but if I am welding something thinner like some thin walled exhaust pipe I turn the welder onto a lower setting but when I pull the trigger the welder just spits every second or so there is no nice crackling/sizzling noise? I have checked the earth and it was fine as when I turned the welder back onto high setting and tested on thicker material it welded fine but as soon as I turned onto lower setting it was spitting again?
Question 3: last question here thanks for baring with me so far, this is regarding the auto/manual wire speed feed. The instructions say about an automatic feed speed pre set for each power setting but it can you can manually over ride it......there is no switch to do this to select auto or manual so is the manual or auto done my putting the speed feed dial onto as low as it can do??
Thanks for any help in advance
Craig
Craig
I will post up the results with the voltage when I get a chance to test it as I have a multi meter so that'll work fine.
