dirty big Hefin!
select the most appropriate welding method or proccess and give clear reasons why that method offer advantages over any others. you should give examples of the technical settings used for each machine in addition to the gas (if any) or electrode types used.
1. Construction of a marine fuel tank in 1.5mm stainless steel sheet.
2. Construction of a heavy duty boat trailer in 4mm mild steel box section.
3. Replacement of a damaged wing on a motor vehicle.
4. Building of a marine craft hull in 4mm aluminium sheet.
I would be grateful if you guys could help me by giving advice and opinions on the techniques used in the welding process to achieve those four examples.
