Ti's easy.....if you use ABS Pro from steady tech. (And a slurry from pure ABS)We dream of (successfully) printing ABS here! One day...
Yep I have access to a Stratasys F370 who’s material properties start at ABS and go up from thereTi's easy.....if you use ABS Pro from steady tech. (And a slurry from pure ABS)
Sadly I can't find it any more.
I have a decent supply of it all be it in Natural or Gold colours....so if no one else manages it send me the STL.
ABS is a good idea, my youngest printed some car speaker mounts in the standard stuff PET? and they majorly deformed once the sun shone. He has since reprinted in ABS and they have so far retained their shapeNeeding someone who could print this in ABS
Given the loading and shape, I'd print it on edge, so you're not solely relying on layer adhesion for strength.I would go for option 1 - the solid. It will need supports somewhere. I'm thinking to print it upside down. Let's get the model first and work out the detail from that.
Standard is normally PLA.ABS is a good idea, my youngest printed some car speaker mounts in the standard stuff PET? and they majorly deformed once the sun shone. He has since reprinted in ABS and they have so far retained their shape
It was pla that he used that deformed badly. Definitely abs that he used that has been ok since
That's good as superglue is also affected by water.Got a chance to try the acetone and I didn't think it was going to work as it hardly seemed to touch the printed part. It did act well on the ABS however so I gave it a try. It seems to have worked, let it sit overnight and now if I try and prise it off the panel bends and I think it would likely break the panel before it separates so very happy with the result
Once again big thanks to @Bladevane![]()
