puffernutter
Puffernutter
- Wiltshire
Initial firing and then occasionally along the workpieceIs the failure upon initial firing ?
Or after the arc get's transferred ? (or attempts to xfer)
If it was when trying to xfer, I would suspect the main ground to the plate.Initial firing and then occasionally along the workpiece
In my experience they're a bit of a hail Mary. They're usually very narrow band and limited in their blocking capabilities. Unfortunately as the issue seems to be affecting @puffernutter's USB then the frequencies you want to block are probably the ones that you need to let through...Have you always had a ferrite ring on the USB cable, or did you add it to try to solve the problem?
Since USB is digital, a ferrite bead will tend to slow the risetime the signals, which could cause timing problems.
The hypertherm 350 is snap start ?A quick update. I have spent the last two days making a new fitting for the Hypertherm 350 torch. As suggested, I thought I'd try a larger machine (as I had one I bought recently off a gent from this forum) and I had the chance to try it today. Whilst I had bought a USB isolator I decided, in the best of engineering trials, not to change too much at once! The only change I made, as the Hypertherm had longer leads, was to site the cutter unit a little further away from the table. I did a trial cut on 3mm plate, which it cut out with absolutely no issues, no stopping, spluttering and the connection was sound throughout. I wonder if the Hypertherm with a higher current is able to maintain the arc better and there is much less interference on the USB. Anyway, until the next problem raises its head (well it has, but that is just my lack of experience with G-Code) I think we can close this one off!
Thanks again for all the ideas and support - much appreciated.
Peter
All I can find is "The PAC110 torch is an instant-on torch which produces a plasma arc immediately after the torch start switch closes." from the Operators Manual. The unit is now discontinued.The hypertherm 350 is snap start ?
You have switched from a Hi-freq start R-Tech plasma cutter, to a Hypertherm 350 with snap start ? (no hi-freq)All I can find is "The PAC110 torch is an instant-on torch which produces a plasma arc immediately after the torch start switch closes." from the Operators Manual. The unit is now discontinued.
