puffernutter
Puffernutter
- Wiltshire
A while ago I moved my CNC plasma set up It is now in quite a small block built room. It is a home built system using a small R-Tech plasma cutter and the controller is driven by PlanetCNC software. The controller, motor drivers, relay control of the plasma is in an earthed metal box, fixed to the wall about 500mm from the edge of the CNC cutting table. The R-Tech plasma cutter is on the floor on the same side. Cables to the steppers are 4 core screened. The PC is a HP desktop higher up on the same wall. The connection between the desktop and the controller is USB. I have fitted a ferrite at one end of the cable.
The problem I have is that if the arc fails to strike I get "Communication Lost with Controller" and everything freezes and I have to unplug and re-plug the USB lead to the controller and through the menus, reconnect the controller and all is good! This is happening quite often. Additionally, I have just changed two of the stepper drivers, that just stopped working.
My suspicion is that if it takes too long to strike, the high frequency used to ionise the air between tip and workpiece is affecting the USB signals. I should add that a lot of my career has been spent involved in railway signalling with EN50121 (all parts) which is interference between trains and signalling systems, so I am familiar with what interference can do (although this plasma cutter has nothing on the ringing you get when a DC train turns on, or a 25kV pantograph arcs!
Its not easy, but I could put the PC the other side of the wall, but there would still be some USB cable close to the plasma cutter head. I could possible move the controller, although that would involve extending the leads from the controller to the steppers and I am not sure if that would make things better or worse.
How do others have their set up and have you had this issue?
Cheers
Peter
Cheers
Peter
