ajlelectronics
- Gloucester, England
As you can see, if I am keeping this DB, I could do with some blanks.
Hi,It isn't prohibited in the current regulations (not since the 14th). See here for more details:
https://electrical.theiet.org/wiring-matters/years/2018/70-may-2018/myth-busters/
There are good reasons why you may want multiple phases serving different equipment in for example a data centre.
For sockets, I would still tend to group an area on the same phase for logic if nothing else, unless there was a compelling reason to do otherwise such as load balancing. I'd still label it as well.
Hi,
But if I reading the link correctly it still is prohibited, the exception being, “A.20 All socket-outlets in any one room shall be connected to the same phase (or pole of a 3-wire system). Exemption: In non-domestic premises, if it is clearly impractical to comply with Regulation A.20, more than one phase (or pole) of the supply may-----".
Or am I mis-understanding what your saying.
I always believed in any domestic situation you never combined phases in any one dwelling and you kept separated as much as you could phases in commercial/industrials properties and you labeled the heck out of such sockets and switches if phases were combined in any one, ( touching ), area.
Thanks, the link activated activated a long forgotten memory and the updated advise surprised me a little, I've forgotten much of the detail so will have to fill in a little.The quoted text is taken from the 14th Edition of the Regulations issued in 1966! The article is tracing back to where the stipulation originally came from, and why it has been superseded with updated advice.
The current (18th edition amendment 3) has no such regulation.
The majority of UK domestic dwellings are going to be single phase anyway unless you are talking about HMO/Flats etc, although three phase domestic is starting to gain traction with all the solar and ev requirements.
It would be a bit pointless having three phase if you can't balance the load...
You do need to label where things are fed from multiple supplies with separate isolation points and where line to earth exceeds 240v where it wouldn't normally be expected.
I don't think phase to phase voltage on a three phase installation would be really be unexpected, but a suitable warning label where two phases are in close proximity to each other wouldn't exactly hurt either IMO.
