malcolm
& Clementine the Cat
- Bedford UK
I want to lower a drainage hopper by around 275mm to put it below internal floor level and add an inspection chamber like this one http://www.pavingexpert.com/drain15.htm where it joins the foul drain.
The drain pipe and cast bathroom waste pipes are about 250mm apart so I'm looking at two hoppers side by side. Ideally I would have the bath waste one drain into the main one and have a single P trapped pipe to the inspection chamber.
How does this tend to be done?
). Maybe I could connect that to the other side using easybends.
