zzr1200
Working at 650 ft on open steel work.
- Glapwell, Chesterfield, Derbyshire, UK
The garage doesn't appear to have a dpc in the wall, the internal floor is higher than outside concrete path.
Answer....Yes or No to remaining questions
1. Do you have or ever had a damp problem in the garage caused by the path?..........
2. You have stated there was weak concrete there before, which I presume is why you're replacing it??...........yes
3. Will installing a dpc around the patch make any difference to the rest of the building damp proofing???...............no
4. Is it worth installing a french drain for a 5ft patch in a path against a longer building????.............
probably not
5. Provided the path repair doesn't cause any extra water pooling than before, will it make any difference?????..........no
6. Is it worth worrying about??????...........
7. Does it really matter???????..........
probably not5. Provided the path repair doesn't cause any extra water pooling than before, will it make any difference?????..........no
