AVI_8
- Prestwick
It’s going to be about 1.5 times the height of the compressors with an opening behind the fans which will draw in air from outside, also it will have doors which I can open to allow air to extract when in use, as long as moisture isn’t getting in which I’ll build into the design dampness shouldn’t be an issue as long as there’s ventilation, put it this way my garden sheds are dry, similar design but with an inlet for airflow and adjustable doors either end to let hot air out.What sort of housing are you going to go for?
I was thinking of the same but it is a tricky balance. Reason being the compressors will require air flow and also to dissipate heat from running.
In a small enclosure this presents problems because even if using acoustic louvres (cost prohibitive) they are also letting the damp outside atmosphere in when not running. And if near neighbouring properties noise could be an issue. Hence I put my compressor in my garage attic.
Edited to say that nearest neighbour is about 150 metres away, the base will be a platform like a decking 1 metre by 3.6 metre made from 4X2 joists sunk into the ground above fence posts into concrete with rubber between the compressor feet and the floor which will be 1 inch slats onto the 4x2 frame
