why doesn't it apply to all piston compressors?
Hi hsgb, If I was you I'd hang on to that compressor, it's a beautifull machine, it'll see you out & your kids out!! I have the same model,mine had a 3hp 3 phase motor on it & I changed it for a brook 3 hp single phase, it takes a while to fill the tank to 160psi but the tank is soo large it lasts for ages at tool pressure, as tigler says' I wouldn't upgear it faster it's made for that speed, I also have a homemade one which I built nearly 40yrs ago it's a clayton dewandre air brake pump from a green goddess with a 2hp motor bounted on the ubiquitus ''propane bottle'' not 2 stage just a twin & I've sprayed cars with that o-k so the teclamit will easily cope, If you do find any info about it I would be interested in it regards the artfull codger
slan go fol
If you do find any info about it I would be interested in it regards the artfull codger slan go fol
