Memmeddu
- Italia Sardegna
Hi everyone someone knows an trustable online calculator or application to correctly calculate
Effective compression ratio
And dinamic compression ratio
Thanks in advance
I've used one but the resulting value seems strange to me .
It says that with a static CR 8.6:1 and considering the valve closing timing (only the closing without considering the opening or overlap) and rod length,bore and stroke ,the effective compression ratio is 7.4 but it rises up to 12.65 with 10 PSI boost
Seems high for the amount of boost
Thanks in advance
