burrows1980
- Buckley, North Wales
Hi,
After a few months off, I've decided to get my home built silent compressor working again. I used pneumatic push fit connections but one exploded
so I'm thinking of going down the road of plumbing compression fittings.
Does anyone know the working pressure of these fittings? I've seen in the reducing water in the air lines guide on here compression fittings being used:
Its going to be the same setup as last time, 4 x Air Con units but with safety cut off swt's on the compressor sides before the NRV...
Gaz
so I'm thinking of going down the road of plumbing compression fittings.Does anyone know the working pressure of these fittings? I've seen in the reducing water in the air lines guide on here compression fittings being used:
Gaz
Good to hear that's the only damage it caused. Could have been quite a nasty little incident.
