Hi guys, new user here.
I'm currently working on restoring an old Honda CB750 and have been paying for a welder to do some seemingly minor work which has been surprisingly expensive. As I now need to have a couple of brackets welded on I'm looking to just buying my own welder and learning to do it myself.
The range of thickness I'll be likely working with is 1.6-3mm but I suppose it would be good if I could do slightly thicker for potential future versatility. It will only be hobby use.
From what I've read so far a MIG welder would suit my needs and be quite flexible in use, but I'm not really sure what I should be looking at in the specs when I compare different models.
I'll be using it probably exclusively in doors off a standard 13a plug
Does anyone have any model suggestions that may be suitable? I'm happy to buy second hand too if that means getting a better unit.
Cheers!
Cheers!
if you come up to Gloucester, your welcome to it.
