T0rnado69
DIY nut !!
- Essex
so i got myself one at last.
its 125mm diameter with 95mm register.
the plate on my lathe is 132mm diameter and a 100mm register.
now i could open it upto fit. but holding it will be a bit awkward. and then if you end up with runout then your stuffed i guess.
also the bolt PCD is different too.
so i guess it would be best to make an adaptor to go between the two.
had a measure and it looks like it needs to be out of 15mm plate.
it best to use steel or ?
cheers.
cheers.
