BoogerGrinder
New Member
- Sydney Australia
That doesn't look like a cold cut saw blade??
This sounds great, but unfortunately I am not in the UK.This place does 350mm TCT blade sharpening for £15.60 including return postage, all you've got to do is send it em cheap.
They also repair teeth included in that price:
"We'll apply new teeth to your blade if required absolutely free, providing the number of teeth isn't greater than 5% of the number of teeth on the blade, after this teeth are charged at £3.00 ex vat each and you will be contacted for additional payment. For example with a 60 tooth blade we will replace 3 teeth for free and anything after is chargeable."
Planning to use them myself soon, disclaimer that I havent used them yet - but 99% sure I found them on here somehow. 10% off first go as well!
TCT Saw Blade Sharpening Grinding and Repair Service
TCT saw blade sharpening service for 85mm - 750mm diameter saw blades. We can service all types of TCT saw blades for cutting wood, plastic, aluminium and steel.www.thesawcentre.co.uk
Correct, the saw is a Bosch GCD 12 JL.Not if you're talking about the slow-speed HSS cutoff blades. It is one of the new breed of metal cutting TC blades which are also commonly referred to as cold cut blades.
There you go, you learn something new everyday. I can see why the the terminology gets mixed up though, no matter the cut, the end of the steel is cool to touch as soon as you are done.Cold cut at 1500 rpm? I sincerely doubt it. Cold cut typically refers to speeds around 100 rpm, these carbide chop saws are commonly referred to as dry-cut.
