Crikey,that`s a blast from the past.![]()
Mark, was that lathe from South Ghyll or Crewe Toll ?
AWEM
(ex Ferranti myself!)
Andrew,it was from Crewe Toll.Did they have a machine shop at the Gyle?
I went to Napier Tech when I was an apprentice,with loads of Ferranti guys.All from Crewe Toll and Robertson Ave.South Gyle didn`t exist in these days I think.
Mark.
CVA 55yrs, Not even run in yet, but maybe time for an oil change![]()
Were you the lucky man with the winning bid then?
, and how I do. Understand where you're coming from stormin, but a lot of people get caught by a "name machine", de-rusted and a new paint job - a lot of ex-industry machines are ready for the smelter. ''the tone of your post there is nothing to tell you'' ''you have only used one serious industrial lathe'' hmmnn that's a bit strong isn't it? I was merely asking for your expertise on these matters as I'm interested in another lathe & wondered what the faults with colchesters were, having said I've owned one for a number of years without any trouble,& as mentioned in my post I've used other ''serious industrial lathes''Well I would,but I gather from the tone of your post there is nothing to tell you so I won`t,and as you have only used one serious industrial lathe there is no point.
For the people interested in price,an early roundhead Colchester is always a stronger machine than the later squareheads.The later ones are really soft.
CVA`s,DSG 13 x 30`s and Butler/Elliott 460/550`s can be bought for £400-750.The CVA weighs about 1500kgs,the DSG slightly more.
If I had to buy only one lathe I would buy a Ward or a Herbert capstan lathe unless I needed to do screwcutting.These things are all at least 25yo,most of them going strong,very reliable and cheap.Downside is they are heavyish and deep so need a bit more space but the Herbert 2D and the Ward 2 series aren`t bad.
Mark.
always comes down to cost vs use..... can you justify having 2-10k of machine that you use once a month when a £700 machine will do the job you want?
different if you need the extra precision or are using all day every day...
Not that I will be selling it
Well I've just picked up a British built M300. for daft money. needs regrind, at a cost of 600 to including the head and tail stocks hand scraped back in to alinement to take into account the beds been reground. But once rebuilt I will have a good as new lathe for less than a scrapper off the bay of fleas. Worth around 6kNot that I will be selling it
Result!!!
I'll start a thread once I get stuck in with the renovation.
"Ive only took a thou off" yeah and 16 thou to put it right.If your happy with just a ground finish on the slideways then fine. But a proper machine is hand scraped to achieve the finish on the ways. A ground finish no matter how fine is microscopically a series of ridges and valleys, some of the ridges eventually get worn away unevenly to reduce accuracy. The worn metal from the ridges contributing to even further wear. A ground finish also has very little affinity for lubricating oil.
A hand scraped finish has lots of little hollows, these hollows can be likened to a shot peened finish, toughening the surface. The also serve to maintain a film of oil between the mating surfaces reducing friction and wear. The high spots on a scraped finish are less pronounced and less likely to wear into a grinding paste.
A hand scraped finish on a lathe would cost in the order of £2000 for a short bed machine. A grind can be done much cheaper.
