CNC Plasma
  1. Gizmo.Y Member
    836
    Skegness
    Morning folks, i'm currently looking into getting a small CNC plasma table for the shop. Im waiting too long now for simple small profiles from 3mm mild steel that are holding up production, sometimes for more than 2 weeks on a simple 30x30 profile...
    I use mainly 3mm Mild Steel brackets, along with some 5/6mm Mild and some 10mm Mild and Stainless exhaust flanges (Including head flanges)
    I've been eyeing machines from Xtreme Plasma, formally machines offered though RTECH (https://xtremeplasma.ecwid.com/)
    Their 4x2 Bed ticks all the boxes when it comes to available space in the shop and the hole i intend to stick it. Their 4x4 Bed is nice...But its just slightly too big and will make the space very cramped and uncomfortable.
    I have a 3D printer i used to print lots of tooling, so i'm used to having to fiddle around with it every 100 hours or so.
    I'm torn between getting a CNC plasma Bed or another 2 post lift....But im sure i can keep the plasma cutter very busy...
    Does anyone have any experience with these machines?
    I'd prefer a water jet table, but unable to find pricing/ sizes for a 4x2 or 4x4 table (if they exist) Let alone in my pricing range.
  2. Bladevane
    Bladevane Member
    630
    Harwell, Oxon
    Rob from Xtreme is your guy. Very helpful and enthusiastic.
    slim_boy_fat likes this.
  3. xtreme engineering
    xtreme engineering New Member
    9
    gloucester
    4x2 can be upgraded at any time to a 4x4
    julianthegypsy likes this.
  4. Brad93
    Brad93 M J B Engineering
    7,476
    Essex
    You won’t have much change from 100k for a water jet.
  5. Ali
    Ali Member
    652
    Cheshire
    You could buy a ‘Wazer’, but good luck getting it. I’ve had one on back order at work for 2 years.
  6. DTS Member
    168
    Rugby
    Had a swift-cut Swifty. Was a great machine and I had a Hypertherm XP45 on it and later a GYS 70a cutter. Both worked well..
    Might be a bit small for you though at 610x610.
Advertisements
