steviec_lj
Rust Welding Professional
- Barnetby, N.Lincs
Secretly looking to get a CNC Plasma in the barn, hopefully without the wife noticing.
Looking for something fairly substantial, that will take 2000x1000 sheets, maybe up to 2500x1250! Currently buy in bits from the local cutters, in a range of thickness from 1 to 12mm and the only limiting factor is that we’re on Single phase, at the end of the run from the transformer, but we get a steady 240v and haven’t tripped or burnt out the 100a incomer yet, despite trying!
Clean cut up to 10mm is a must, severance on anything above be that would be acceptable - I don’t mind a bit of clean up.
Space isn’t an issue, funds, there’s probably £10k or so I can put together.
UK made would be brilliant, as the support would hopefully be easy to obtain.
Any recommendations for tables? Packages?
