superclarkey
- West Midlands
I believe it does, unsure just knew it was what people used so thought I would get one. Maybe someone can shed some light on this?
I'm surprised no one has given you this link to date (I didn't see it on the previous page anyway)
haha, can you tell me if you went for stepper motors or Servo close loop type set up and trying to work out the cost difference etc.
interesting I have an R-tech plasma and it seems fine for what I use it for. what did yours not do??I bought it as a off the shelf ready to go package, so comes with the touch, and I know what you mean its like £500+ for a replacement so I will be taking very good care of it thats for sure!!
I set the gas pressure and away I went, I used a straight edge to do that cut and just nice and steady movement, (I've not owned a plasma cutter before, but I've used loads) so I know the travel speed, it was a perfect cut, hardly and gross or whatever they call it and it was smooth to the touch, I'm sure as the torch consumables wear out that it will go down hill.. But having the shielded shield cap on the end makes a big difference.
I had an R-Tech plasma for a while and it as just a waste of time, This is worth every penny and I'm sure the gun makes it amazing too.
Like you the only reason I bought this machine is for CNC future capabilities, I will actually really ever cut more than 10mm, and normally around 5mm max most days.
