simonlpearce
New Member
Hi all,
I don't often post on here, mostly just read for tips/advice. Anyhow after recently changing a front wing on my track car for an MOT, I decided to paint it the right colour. However after applying 3 clear coats it now has a dull haze to it. Pics below.
It had 3 coats of primer which was wet sanded with 2000grit. It then had 2 coats of base which were then wet sanded again with 2000grit, then another 2 coats of base. Then after 3 coats of clear what you see below is the final product. I haven't tried anything on it yet as from the limited reading i have done you need to let it cure fully before going nuts with any cutting/polishing compounds.
Can anyone advise what the best steps to take here will be?
