Yes, just have some non slip vinyl under her now.Unreal how a hot radial tyre will lift floor paint is it not....?![]()
SBR at the very minimum will dust proof at least a concrete floor but make sure you get the laitance layer off whatever. The SBR is waterproof.
I remember using a wetroom tanking kit, the instructions clearly say if you run out of the supplied "special" primer you can use SBR...which oddly looks and smells exactly the same as SBR...![]()
it is the special primerSBR at the very minimum will dust proof at least a concrete floor but make sure you get the laitance layer off whatever. The SBR is waterproof.
only quarter of the price used in ka tanking slurry and by sovereign damp proof suppliesi use carpet in my old garage
yes if your garage is wetSoaks up the damp?
Can you use it like that without painting over it? How long does it last?I have used sbr on all the concrete floors as they are. I dont paint it on I flood them with the stuff, sweep off the excess the following day and let it dry. Works a treat.
Bob
yea its ok to use without being painted, if it gets hard use just re apply a bit now and then and it will soak in to the porous concrete and harden it upCan you use it like that without painting over it? How long does it last?
