Hello MIG experts. I have decided to teach myself the basics of MAG welding, as everyone and their dog seems to use this. I am familiar with stick welding, so should get the technique at some point, but some of the MIG equipment confuses me.
I have decided on a Clarke welder as I dont have a lot of money to spend, only want to weld up to 3mm steel, and need it to run off a 13amp fuse.
So, firstly, will a 150 turbo do 3mm steel? And I would like to use gasless wire sometimes. Will I need a gasless model, or can any welder be used for gasless as long as you use the right wire? And will a Clarke 150 TE run on a 13amp fuse?
Is this the right welder for what I want? And Weldequip could you send me a quote for something suitable, as I'd rather get it off you then Machine Mart if poss.
Cheers!
Cheers!
