Shedendman
I have an old clarke power hacksaw,i say old as its build date is 1987.
Anyway dragged it out today to cut some 50x50x2mm box only to find its cutting offline
for the life of me i dont know why
here it is all set up ready to cut,the stock is clamped up tight as and is flat on the bed
the cutting starts fine but as its going down you can see the blade starting to bow/twist away,not easy to capture this as it was moving while taking the photos camera angles etc
bit blurry this one as the saw was cutting at the time,but you can see the blade slightly twisting away from the line
Resulting in this
Now as i look at this the box dont seem to be flat going by the angle of the clamp(make sense?)but it is a steel rule shows me the beds ok,the blade is tightened up as far as it goes,the vice/clamp is holding the box firm ie no movement while it cuts but its still not cutting true,also blade is not that much used,say its had about 20-30 cuts,can anyone throw some light to whats wrong please,its driving me nuts
for the life of me i dont know whyhere it is all set up ready to cut,the stock is clamped up tight as and is flat on the bed
Resulting in this
