burntmebonce
999 on speed dial
- cambridge
Just reserved my new mig at mm the guy I spoke to asked if I had a 16amp supply saying it won't run on a 13amp plug any advice ?
What, like putting a 16A plug on it instead of a 13A you mean?you can convert a 13amp to 16amp with simple adapter plug anyways mate. there pennys to buy really.![]()
The cable isn't normally the issue as machines supplied without plugs are normally intended for use with a plug rated higher than 13A.its all well and good having the plug rated at 16 amps but the cable needs to be too
As Brightspark says, it's when people fit a 16A plug on their machine then have a cable with a 13A plug on one end and a 16A socket on the other and think it miraculously magics up another 3 amps when you have to start asking questions.![]()
The fuse doesn't go in the plug top, it goes in the body of the plug, then you screw the top on.
just to addPedant![]()
just to addpeople call sockets the plug and the plug plug top
its a socket and plug
Easy, look at it. Does it have holes or pins? An inlet is a male (plug) because the live section has to be shrouded, making that a female.
after 40 years u might have lost the plotI think after nearly 40 years as a spark I know the difference between a plug and a socket![]()
