JonnyAlpha
Trying to get my Clarke 160EN Turbo setup for the first time and I can't seem to get the wire speed correct, what's hampering my progress appears to be a wire feed problem.
When the torch is activated the wire feeds for about 1 to 1.5 seconds then stops for 1/2 second or so then repeats the process.
When this happens the motor and feed roller rotates normally but the wire slips.
After stripping the whole thing down (not yet removed the liners) it appeared to be OK and was still feeding fine with the swan neck fitted however once the contact tip is on it just seems too much and the intermittent feed re-appears.
The swan neck liner protrudes beyond the aperture where the contact tip screws in, is this normal or should it be flush with the end of the swan neck?
I have a spare liner hose and swan neck liner and having stripped it down once will try and replace them and see if this solves the problem.
I bought the welder second hand on this site and its only been used to weld 300mm of steel, the wire was rusty but I removed all the affected wire and the wire in the liner appeared OK, so no rusty wire has been fed through the liners.
I understand from this site that when setup correctly the wire friction screw should just be done up enough to prevent the wire from running on and birds nesting and the feed roller should slip when light pressure is applied to the wire at the tip end.
Does this sound like a liner problem.
