where do we get the 16 amp fuse from and the braker. have seen meny welders use 13 amp plugs an nomal house hold elecrice-----------------
The wiring will be rated at far more than 13 amps. Bear in mind that household electrical systems are designed to have something pulling 13 amps plugged into every single socket and still not cause fires.
most houses need 2 ring mains down stairs and one up stairs .a cooker circuit would be min 30 amp up to 45 amp on its own supply . the welder wouLd be no more than 16 amp
