ronsealdeath
New Member
Hi there,
I'm a newbie novice and have just purchased a Clarke 150te Mig off fleabay for the pricely sum of £47
. Its a bit of a sorry state I must say but amazingly I have got it to weld thanks to some new wire and gas. I've always wanted a Mig welder ever since reading Custom Car aged 11 and seeing people crafting amazing things out of metal. Now I'm 32 and I still get excited about it. I've finally got an excuse in the form of a rusty Land Rover Disco Mk1 so I took the plunge with this Clarke unit.
I have a couple of questions if anyone can help;
The side panel is missing (the one to cover the wire), does anyone have the dimensions of one so I can make a new panel from some steel or alloy?
Also the spool/spindle was missing so I had to cut a hole of wood about 3/4" thick to thread on and support my wire reel, I've then used a large washer and two nuts to hold it in and stop the nut tightening further. Do you think this will work long-term? It seems to be ok in the 5 minutes I have tried it out. I couldn't find a spare spool on the internet for the 150te.
There is no trigger on the torch and instead just a small button. Did the torch always have this or has the trigger broken off? Can I get a new one?
I've been on weldequip and ordered a new swan neck (current one melted and covered in tape), shroud, contact tips and liner for the wire. Hopefully it will have some life left in it then. Its an old model and doesn't seem to have a fan that turns on when I put the power on, did they all have fans in them or is it just shot?
Sorry for the zillion questions, once I get going I can bug you guys with more questions about how bad my welds are!
Thanks in advance
Al
A
Swansea
Additional - Sorry I think I posted in the wrong forum, apologies but I can;t seem to move it to the bit on Clarke Welders now!
Thanks in advance
Al
A
Swansea
