clarke 110en turbo no gas manual?
does anyone have a copy of the user guide? im unsure of the power (AMP) settings it has two switches 1/2 min/max but i dont know which setting for what thickness, by the way im also a newbie to welding.
Can't help with a manual sorry but set as follows:-
1/Min for thin sheet such as bodywork
1/Max if you are using thicker sheet to patch up bodywork
2/Min or even 2/Max for Chassis work, or anything up to 3mm
Each time you up the power increase the wire feed speed slightly, and likewise each time you drop the power turn the feed down a bit.
weldequip
