Hi are you useing the right size tip for the wire you have in your weldermy mig welder is doing my head in .when I weld straight away the wire stops coming threw! and the wire is wring to push the swan neck off!! I pull the neck off and it looks black and tangled I have replaced the neck liner and the tips and shroud. still the same thing happening pixxing me right off know. only New swan neck I could try. if its not that I have not got a clue whats wrong please help
As I said, are you using gasless tips, 1mm I think they are, is there a good joint between swan neck & tip etc.its burning half way the neck! its gasales wire I am using
