SaccharumBB
New Member
- Bedfordshire
Hello all
I have come by a Clarke 102 NG mig and would like some advice from you members.
I have browsed some posts on here and although it doesn't seem to be a great bit of kit, it was free and I have been pondering getting a mig welder for sometime.
I would like to do some car body repairs with it ( bodywork and thicker bits ) but from when i've read the lowest setting of 35A it too high for thin sheet metal.
Haven't actually done any welding with it yet but i've given it a strip down and clean and everything seems to function, so........
Can you tell me what welding wire you would recommend?
The clarke stuff is poor so who makes and sells the good stuff? Is there one brand that those of you who are experienced at this would trust? Probably go for a 0.7/1kg spool to start with. I've come across Oxford welding supplies and SIP.
Also the wire size that came with it is 0.9mm flux core and I think from looking at videos and reading on here that I will need a thinner wire if I am to try to weld 1.2/1.5mm sheet. According to what i've read flux core burns hotter with more chance of blowing through so would 6mm/8mm solid wire be a bettter choice?
It may well fail to do what I want but it was free so i'll give it a go. Obviously testing it on some scrap first.........if I can find any.
thanks in advance
thanks in advance
