Headlight has a main board which feeds off to each individual bulb. All other lights in the unit work as they should so presume it must be this specific LED board that is at fault?
The LED did function before just not correctly (flickering when on DRL then intermittently working albeit dimmer than the opposite side whilst on position lamp setting).
Do you get generic boards like this that I can try and graft in if I can’t get a old headlight to replace this one with?
