- Birmingham
Does anyone recognise this model of fill valve please as I would like to replace the seal which is leaking.
			agree swap it out not a bad job to do if you got a isolator valve easy oneThat's called a rip it out and fit a new one
A £4.00 spend or a £16.00?That's called a rip it out and fit a new one
Is this causing it to dribble into the pan, leading to it re-filling every so often? Mine (also a SIAMP) is doing similar, and I keep putting off fixing it. I've seen a video showing how to clean the washer, but when I tried to remove the fill valve by twisting it, I couldn't get it to move. I've since seen another video that suggests I need to push down and turn, and I'll have to try it soon.
 the cistern is mounted so far forward it traps the nut against the pan.
 the cistern is mounted so far forward it traps the nut against the pan. and hope that cures it or I can see a replacement of complete toilet.
