As title, looking for a circle cutter kit to fit an iTECH CUT40, I've seen the Trafimet cutter kits on Ebay but it states these are to fit a Trafimet torch. Can anyone recommend a suitable kit?
Shop River Weld (aka Weld Cutter) on ebay should be able to sort it.
Just scroll through the Plasma consumables on there to identify the torch you have and the ceramic shrouds it takes to then find out which is the correct circle cutter you require.
Thanks for the reply Gareth, I don't suppose you could furnish me with a link? Sorry if I'm being dim but I tried searching on Ebay shops for River Weld and Weld Cutter and came up with nothing?
If you know which torch yours is (cross ref on their consumables lists) you should be able to identify which circle cutter you need. The exploded parts drawings for the torch consumables show the correct circle cutting attachment and reference/part number required in the bottom right hand corner of the parts drawing.
Thanks for the link Gareth0123, I think what I'll have to do it measure the diameter of the shroud on my torch as my machine is an iTech and doesn't have Trafimet torch (unless they make them for everybody?) and then I can see which kit will fit. Sorry to see dim but I've only really just started looking at this
