Hi guys
I have been looking for a good old British bench/pillar drill for some time and have been reading various helpful comments on the Forum about what types to buy.
I have recently bought locally off eBay a Churchill Pillar Drill (although it was not advertised as such). I went to look at it before the auction ended, which was when I discovered it was a Churchill, did a bit of research on the internet and found Brightspark’s posts about his Churchill Pillar Drill. I hope I am still using my drill 30 years after its purchase like Brightspark (not least since I will then be in my 90s ...).
I have been giving the drill some tlc and a repaint and have attached some photos – one as bought with the drill standing in my trailer, about to be lifted out with a block and tackle, and three after its repaint/refurbishment.
I have a few matters on which I would appreciate some assistance. First, there is no indication anywhere of the different drill speeds. There are four pulleys inside the belt cover (see photo) and the belt is currently on the bottom pulleys, which I am guessing is the slowest speed. Does anyone know what the (four) different speeds are?
Secondly, a brass plate at the front of the belt cover says “Fill oil cup daily”, which I assume is needed if it is being used daily but otherwise only as and when it is used. What sort of oil should I use? Light general purpose oil? Mineral car engine oil? I assume the oil cup is at the top of the thin tube behind the front pulleys (see photo) – it can accessed with the cover in place - but am not sure how much to put in. Should it be topped up till it is full at the top of the tube or is it better to put a few drops/a squirt in whenever I use the drill?
Thirdly, at the front of the drill, between the chuck and the brass plate indicating it is a Churchill, there is a knurled chrome knob. What is this for? I have loosened this and then retightened it but nothing seems to happen when it is loosened.
Many thanks in anticipation of your help.
Those of you who kindly helped me with my Atlas Copco compressor problem in Mar/Apr of last year will see the compressor in the background in the photo with the drill in the trailer. I am pleased to say it has been running fine since its new NRV valve.
Thanks again.
Colin
Thanks again.
Colin
