Hi,
Thanks for the replys chaps. Sean is your cheater the same diopter as your normal reading spec's? and Is your normal welding distance the same as your reading distance?
Cheers Gordon.
Hi Sean,
interesting that you use a .25 diopter cheater stronger than your readers, this tells me you must be welding at a closer distance than reading.I tend to be the opposite and weld a little further away, Gordon.
Hi Sean,
Same with me, long distance still great. Have you tried using some sort of anglepoise lamp to put some more light on the job. I know it works for some.
Gordon.
That eBay item is 20 Pounds plus 6 for postage ! Cheater lenses only cost a few dollars in USA ( but you do have to pay for the air ticket to get there ... )..
