zzr1200
Working at 650 ft on open steel work.
- Glapwell, Chesterfield, Derbyshire, UK
So true.....???More importantly what chainsaw did you get?!![]()
can you guarantee that your pallets have remained dry for one year ?Presumably the aformentioned pallet wood (4x4" timber or thereabouts) doesn't need any seasoning, it just needs to be dry before burning?
Having dogs teeth made of nails or old ripsaw blade to grip thin or round stuff in the fork of the sawhorse is handy .. having a six legged saw horse with the middle set of legs about 14 inches from one end allows better safety when cutting smaller logs . Fitting a heavy decently weighted chain to one side of the middle legs to drop over these smaller logs helps hold them down to the ripsaw teeth thus gripping the logs/ sticks .If you're just cutting firewood make yourself a saw horse about waist high out of old timber. It'll hold the wood and it'll keep the saw out of the dirt and the saw is safer and easier to use at waist height. Also you'll not be temped to put your foot on the workpiece. Be careful of small timber the chain can grab and throw small stuff.
Use some of those big uncut pallets and plenty of long screws in pre drilled pilot holes to make as many wood stores as you have space , for cover then in poly shrink wrap when they are full ???My feet will be staying on the ground.
A lot of what I cut will be large 3m x 1.5m pallets which we get buying plate and sheet. They are made from 4"x4" and 5"x5" clean timber with minimal nails holding them together. We have stacks and stacks of them, they soon mount up with the amount of stuff we buy.
I'll also be cutting a few normal pallets up mostly for kindling.
I need to build a wood store. Oh and also fit the log burner.![]()
Do you use a big welders magnet to pull out the burnt nails out the fire box when they are cold or just wait for them to drop in the ash pan when cold .i suggest both circular saw with a metal /wood blade is fine to use
cut the latts first with circular saw close to the 4x4s stick the 4x4s in a saw horse and cut with chainsaw
as gives plenty of offcuts of wood
dig out the nails after from the wood stove its what i do
If you are only crosscutting firewood have a look at the chaps and then spend the change on boots.
Bob
my stove dosnt have an ash pan as homemade as goes for the ash theres hardly any even after the full burn of it after 3hrs with just one log and starters so im not actually chewing through a load of logsDo you use a big welders magnet to pull out the burnt nails out the fire box when they are cold or just wait for them to drop in the ash pan when cold .
Just google Bill singleton chainsaw accident. He had a kickback & drove himself to hospital, Its a sobering xray.Don't cut with the tip of the saw, as there is a risk it will bounce back towards your face!
I worked with a guy who had a scar from his chest up to just below his eye, kick back ! The chain brake doesn’t always activate.Just google Bill singleton chainsaw accident. He had a kickback & drove himself to hospital, Its a sobering xray.
....you will be sweating your balls off,....
