Thats exactly how i was taught to do it years ago.i have oregon blue chain and stihl chain here for the saws, when kept sharp and away from anything thats not wood they are both good chains.
i sharp the chains with a hand file and count the number of passes i take on each one so as to keep the height similar from new it keeps the tooth edge height the same on all teeth, or as near as damn it at least.
tbh i just figured it was the best way i could keep some consistency to the edge.Thats exactly how i was taught to do it years ago.
I never see the need for a grinder. Unless you are sharpening a chain that is absolutely *******, hand filing is cheaper, less bother and you can do it away from home. You can also sharpen a wider range of same pitch chain with hand files, such as full or semi chisel, ripping chains etc.
just tried to get a chain and they are out of stock.I've always used Oregon chain and been happy but just yesterday I came across this site via an aborist site: http://www.northernarbsupplies.co.uk/ their own brand of chain is cheap and been getting some decent feedback from what little I read. A very quick browse earlier suggests they only do a full chisel chain which if you're only used to low kickback and micro chisel chains might not be a wise choice though...
just tried to get a chain and they are out of stock.![]()
if they are decent chains then it was probably inevitable that they'd run out of stock quickly at those prices.they don't last 5 minutes and throw them awaymy tip, make sure your chain file isn't dull
LOL £42 for my saw. Normal chain is £17 & cheap ones £10.
