This may be one of those 'observations are wrong or incomplete' issues, but please bear with me. System is a few years old, but used to work fine (so not an install issue).
Wet central heating system (rads) running from Ideal Logic+ boiler (combi hot water works fine).
Stat calls for heating, boiler fires, radiator feed heats up, and very soon after the radiator return pipe is very hot too. Great, you'd say, job done. Except that no radiator (including the presumed bypass) is returning anything that hot (barely warm in fact).
So there has to be a return path other than rads.
I've just found out about auto bypass valves, but if one is installed here, where to look? Is this a likely scenario that everything is returning via the bypass, with very little through the rads?
