Hopefuldave
Intergalactic pot-mender
- The Shed of Danger, surrey, England
Hi all, Newby posting warning...
Borrowed one of these from a mate for a few weeks, as I have some Thin Stuff to weld (oil-drum to make a furnace, I think the Oxford oil-cooled would murder it), I've sussed that it has wire speed and "power" settings without much trouble and I can see how to tension the wire feed, but wondered if I could find a manual online - the Cemont website denies all knowledge of it when I search for manuals! I wonder if it's also known as someone else's MIG (which I suppose this is, being borrowed...), and they might have a manual to download.... It would be handy to know which spares etc. are compatible, too. Any points to check before I start using it (or at least, learning it!)?
The hose from the gas reg to the welder looks a bit iffy, taped up in a couple of places, and I like to return stuff better than when it left, can I buy cheap replacement hose easily? It looks like the fittings are 3/8" BSP, so they're readily available and cheap (e.g. Screwfix) - if it's anything like TIG, air leaks in the hose will knacker the weld quality even before I start, not good when I've not used it before! I also noticed the wire armour? on the torch lead was a bit raggedy with a few strands poking out, I assume it terminates like a SWA cable in the bushing through the front panel - is this fixable by re-terminating it, or am I looking at a new cable...? While I have it, I'm going to straighten a few bent panels, put a replacement caster on the front and use a bit of my nice 20mm stainless tube to replace the missing handle - should look nice when I eventually hand it back!
Also: the regulator on the bottle (Y size Argoshield light, at least half full, thanks Gaz!) has the output gauge calibrated in psi / bar (up to 20 psi, 1.4 bar), how do I convert to litres/min, if that's possible, or do I need to add a flow meter downstream of it? I think I have one lurking in the Shed of Danger, ex medical oxygen, which goes up to 10 or 15 litres/min... I think it has the right threads, too
I've used TIGs before, although my efforts on ally weren't pretty, and have a basic clue of flow rates, but they had flow gauges (the floating ball type), and that was TIG, not MIG... Should I just guess / trial and error?
Any hints and tips welcome,
Cheers all,
Dave H. (the other one)
Cheers all,
