Dehumidifier.
Rendered external insulation would be a good way to solve the damp walls.
Over here they consider the bricks sponges you only rarely see them being used
I'm sure I'm missing your humour, but if you have a damp workshop, a dehumidifier, would help, surely ?A "dehumdifier" in Scotland!
that stuff is as bad as concrete on walls if water gets behind the board and freezes it will damage the wallRendered external insulation would be a good way to solve the damp walls.
french drain and increase the overhand of the roof? If you eaves are high enough a lean to walkway all around and weather board? there are plenty of options, all spendy but if the issues are coming from the outside then sorting the inside makes little sense.There’s not a lot I can do with that….the bricks are like sponges when it rains, although I’ve sprayed Thompsons Water seal
i couldnt touch the outside wall even though it has concrete on itThere’s not a lot I can do with that….the bricks are like sponges when it rains, although I’ve sprayed Thompsons Water seal on the outside walls from day1 to prevent ingress..short of building an internal skin of breeze block..expensive and takes up floor space....
Compromises..…eh?
How do you mean as bad as concrete?that stuff is as bad as concrete on walls if water gets behind the board and freezes it will damage the wall
also has the habbit of destoying stone / bricks or other alternatives
Yes..Has it been built on the boundary line?
