Joseph Dorey
New Member
- Dorset, England
Hello (hopefully) friendly hive mind. I'm new here and to forums in general. I'm looking for advice - I have a Cebora Pocket Turbo 130 which has suddenly started blowing the plastic plate off of the back of the brass trigger block. The old block ran fine since my grandad bought it new in the 80's right up until 3 weeks ago when there was a pop from inside the torch, gas started leaking and I discovered it had forced the plastic plate off. I've bought 2 replacement blocks with the neck attached (called a Swan neck if you look for it online), I've attached pictures. The first leaked gas from the captive brass nut in the plastic plate and the second one had the plate blown off as soon as I pressurised the system. ..... help?
In case it's significant - the dial on the regulator stopped working at the same time. It's now just reading as shown in the attached picture regardless of what I do. Doesn't sound like the gas is gushing out when I open the valve on the bottle though, just a gentle hiss
Joseph
Joseph
