POE is good.
Hickvision POE gear is very good.
Is it worth the money over coax stuff?
POE is good.
Yes it is. We use Hickvision on our sites.Is it worth the money over coax stuff?
Not at all.Do you mind if I ask you some more questions then as seeing you have knowledge of these systems?
Absolutely. For a new install I wouldn’t consider anything else.Is it worth the money over coax stuff?
easy enough to tell the diffrence between dog and fox sh..itCouldn't find anything in the thread but can someone recommend a simple single self contained camera that can be simply hung from an upstairs window, or maybe attached to the wall next to it? Power wire can be run easily enough.
The only real purpose is to find out who, or what, is crapping in my daughters back yard. It's a terraced house where neighbours have right off way through the back, but she or I have never seen anybody take a dog through, or even one wandering around. But, she has seen a fox in the street several times, so be interesting to see if that's the culprit.
Looks like smallish dog dung to me, but I shall head off to Google and look into it a little more.easy enough to tell the diffrence between dog and fox sh..it![]()
It has a minty taste....easy enough to tell the diffrence between dog and fox sh..it![]()
Blink cameras will solve that for you..Couldn't find anything in the thread but can someone recommend a simple single self contained camera that can be simply hung from an upstairs window, or maybe attached to the wall next to it? Power wire can be run easily enough.
Agree, good cheap domestic choice, no need to wire, good battery life, take away easy when you don't need and repurpose, dead easy to setup and configure sensitivityBlink cameras will solve that for you..
