Memmeddu
- Italia Sardegna
Ball joint splitter is probably one of the first thing I'll buy ,this morning I've had to remove the steering joint to remove the hub and it's been a pain with Just 2 hammers .A good jack and axle stands are a must. A foam kneeling mat too for us oldies.
3/4 socket set isn't needed for cars, I wouldn’t bother. 1/2" is fine even for axle nuts in 99.9% of cases.
An impact gun (battery or air) will be very handy though, and a selection of impact sockets - you can save money and buy thin wall impact sockets instead of chrome and use them by hand as well. I’d strongly recommend one.
3/8 is not really needed if you already have 1/4 and 1/2 but can sometimes be handy for tight spaces. You need both deep and standard length sockets and a selection of extensions and universal joints etc. Consider buying a good set which has everything in.
You are unlikely to need a 1/4 torque wrench, most stuff on a vehicle is not that critical to torque and in well within the range that one decent 1/2" drive torque wrench will cover - or if you really want, just get one 1/2 and one 3/8 to cover a range of torque.
Spark plug sockets would be a good idea, it is unlikely you will need any spark plug pliers.
e-Torx sockets are a must on newer vehicles
Ball joint splitter (and possibly an air hammer) if you intend to do any suspension work.
For most jobs you will only need basic hand tools, more tools makes life easier but you can usually get by with quite a minimal toolkit.
Spark plug pilers are very useful on my car because the position where wires etc are routed.
Especially for cylinder 2 and 3 , rubber grommet are well in deep into the head , between the intake manifold ports and the injectors rail , wiring etc ,I can easily removed only the #1 the other ones are a pain because they tend to stick onto the spark plug and requires a lot of force to be removed.
instead of solid brass.
