Wightsparks
- Wight
Or more to the point, how do they stop?
I recently acquired a a very lovely 2002 Saab 9-3 Convertible and I'm having an issue with the rear side window.
It was making a nasty noise at the fully closed position when being auto closed as part of the roof closing. So I stripped it down and found that the teeth on the quadrant were a bit chewed at the end section and part of the motor end support was torn (round bit,middle of the pic). So I fixed/welded that lubed it all up, adjusted the stops correctly (as per the workshop manual) and it worked OK manually, but a couple of auto operations later the same issue is back.
The window will close, get to its stop then continue to be powered until the motor starts chewing up the quadrant again.
So my question is - there are no microswitches, and only 2 wires to the motor, no movement sensor on the motor and the motor will turn constantly so no internal interrupts, so how does the car know when to kill power via the relay to the motor - ie when it is all the way up/down.
a) some mysterious method (load sensing on the relay?)
b) it guesses by time and relies on the mechanism stops to just stop the motor (or self destruct in this case!)
c) ????
The later models have a pinch sensor in all windows so you need to calibrate them but this is a different issue.
I have googled this to death and trawled through the Saab Workshop system - nothing.
c) ????
